NI TestStand
Test Stand 3.5 Specify Module cluster defaults
Im using many controls within clusters in specified  vi's into TS (3.5). If i need to change the value of any control i have to undefault the cluster in Specify Modules , and re-tick all the individual control boxes. Is there a simple workaround so that only the control not defaulted has to be unticked?.
thanks dht
(3,176 Views)
  If you expand up the cluster itself and uncheck the individual ones, rather than starting by unchecking the cluster's use default, then that should do it. The "use default" in the tree for the entire cluster, is considered the same as having all the individual ones checked, so when unchecking the "master" version, it unticks all the others.
What happens if you try that?
Working with large clusters makes life easy for passing data in a large chunk, but is it all related to the same thing? (I think of them in terms of "not mixing my addresses with my elephants".)
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(3,152 Views)
daaa!!! seems so obvious when you put it that way!!!!
thanks dht!!!
(3,146 Views)
