NI TestStand
Test Stand. Batch Synchronitation.
"I am trying to implement the synchronizing techniques for my sequence. Through the document, I understood about Bacth Synchronization Step. But it was not clear that how should I use it. Can anybody guide me in this issue ? My requirement is, I have a same sequence for 4 UUTs try to access at the sequence but only one UUT should be able to access. Other sequences will wait till this time".
(3,382 Views)
Hi Saretta,
Have you had a look at the example BatchUUT.seq in the folder \examples\MultiUUT\.
The has a setup that one only one step need be executed such as the "Set Chamber" step.
The step "Pulse Test", this subsequence contains a group of steps that are synchronized to run on each UUT in turn.
It also has a step where no synchronization is required, therefore all executions are run in parallel, such as the "Frequency Sweep" step.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,382 Views)
Thank you for your help, I will look the example.
Best Regards.
(3,382 Views)
