NI TestStand
Test Stand Deployment Error
Built a Test Stand deployment that includes a Labview UI.  When I start the application, I get an error "This application does not support the operating system account type you are currently using.  Try running and logging in as a non-guest"    I can fix this by loading the teststand sequence editor and logging in, but this is a deployment and I don't want to load test stand.  Is there something I can do at the development system to
(323 Views)
Try running this in admin mode
(277 Views)
