There could be lots of advantages to switching to TestStand, but it depends on your application.
1. If you deploy your applications to several different environments or uses (board test, system test, service, field service, etc.) then TestStand allows you to customize different "process models" for each environment. The actual test code is contained in a sequence file. Since the process model is shared by all sequence files, it is a great place to put the common functions such as UUT identification and data logging. Even if you don't need different process models, keeping all this code in one place makes it easier to maintain. There is no compiling with TestStand, so you can change the process model and the changes will take effect in all your applications.
2.
TestStand allows you to easily call many different types of code, not just Labview. You can call CVI, DLL's, EXE's, and ActiveX. I recently saw an article about a way to call Perl code. Again, the value of this depends on your application.
3. If you want to integrate your application with a database, TestStand has great database tools. The database logging utility allows you to log data to any table format.
4. If you are loading test limits from an external source, TestStand makes it easy with a tool called Property Loader.
I suggest you get a free demo copy and try it out. TestStand is incredibly powerful.
Mark (marki@tek.com)
