NI TestStand
Test Stand File menu item entry point execution in VC++ code
Can you please suggest me, how to execute a file menu item entry point pragmatically in a VC++ code.
My process model seq inserts an item called "Select Model" into TS file menu.
i have to programmatically execute this entrypoint from an Operator interface developed in VC++.
Request your suggestion in this concern.
(4,524 Views)
Couln't you just use the PerformClick Method?  So basically you'll have a reference to your menu somewhere in the code.  Get the node of the item you want and then use the PerformClick method.
From MSDN: http://msdn.microsoft.com/en-us/library/system.windows.forms.menuitem.performclick%28v=vs.71%29.aspx
I recommend that vs going through the TestStand API.  It will be a lot cleaner.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,516 Views)
Is "Select Model" a configuration entry point? If so, maybe the following would work:
Command command = seqFileViewMgr.GetCommand(CommandKind_ConfigurationEntryPoints_Set, 0);
command.Execute(parameter depends on how you want to handle errors);
Hope this helps,
-Doug
(4,509 Views)
