NI TestStand
Test Stand. Report html.
I need to know how can to append the date and the serial number in the report at the end of each step result.In this moment The date and the serial number is only at the begin of the report. Thank you."
Message 1 of 11
(4,239 Views)
Hi Dennis,
are you refereing to doing report generation on the fly, or performing a customised report where the date and serial number end up in the report after every step
(i.e
UUT Report
Station ID: UKEMERYS
Serial Number: NONE
Date: Wednesday, June 11, 2003
Time: 9:54:15 AM
Operator: ukemerys
Execution Time: 1.1796946 seconds
Number of Results: 1
UUT Result: Passed
Begin Sequence: MainSequence
(Unsaved Sequence File)
Pass/Fail Test:
Passed
Date : 11 June 2003
Serial Number : NONE
End Sequence: MainSequence
End UUT Report
If it's the former, then have a look at the on the fly report generation examples
{Teststand}\Examples\OnTheFlyReports\
If you're useing Teststand 1.0, then go here
if it's the later, then are you useing the DLL or the sequence to generate the reports. (Look in the appropriate reportgen_xxx.seq file and find the PutOneResultInReport sequence = you can use the stuff in there as a roadmap on how to get the details you want in).
Sacha.
// it takes almost no time to rate an answer Smiley Wink
Message 2 of 11
(4,240 Views)
Yes,this is former. Thank you for the suggestion but I think I am not enought skilful to do so.I did not find
PutOneResultInReport sequence.
Thank you.
Message 3 of 11
(4,240 Views)
How did this question end up being posted by me? Saretta posted it in the LabVIEW forum. I answered and also told him to post to TestStand.
Message 4 of 11
(4,240 Views)
I do not know the reason, I posted my question in Test Stand forum, like you suggest. Thank you.
I am a girl. :O)
Message 5 of 11
(4,240 Views)
Sorry about the gender confusion. Did my response to your original question in the LabVIEW forum help? Do you need an example and if you do, what process model are you using and do want the html or text report modified?
Message 6 of 11
(4,240 Views)
Don't worry about your little confusion!
An example could be for sure helpful.
I use html report models at the moment.
Thanks in advance for your help.
Message 7 of 11
(4,240 Views)
Try these modified files.
Message 8 of 11
(4,240 Views)
I replace these file in C:\TestStand\Components\NI\ModelTestStand but there are not differences with the original.
Could be that I commit errors. Thank you very much for your help it is very valuable.
Message 9 of 11
(4,240 Views)
Oops. I attached the incorrect process model sequence. Try this one instead.
Message 10 of 11
(4,240 Views)
