NI TestStand
Test UUT and SIngle Pass missing during deployment
With the help of this forum, I managed to get a Teststand deployment working.... thanks for the help.
I do have one issue though...I am using the SImple User Interface in a parallel model. In my project, when I open the Testexec and sequence, I have 3 options. These options are Test UUT, Single Pass, and Run Sequence. After compilation and running Testexec, I only have Single pass.
Any idea why this would happen? I keep trying different things but it takes forever to create builds.
Ryan
(5,203 Views)
Ryan,
this sounds really odd. Just by compiling the UI into a release executable this should not happen.....
Could you post a screenshot showing the difference between development environment and release exe?
Norbert
Norbert
Expert: Geometry
(5,193 Views)
Norbert,
Thank you for your reply. I attached two screenshots....one before deployment (on my development PC) and one after (on my test machine). I did see something odd when capturing the screens. You will notice that the "Main Sequence is GREEN on the deployment PC, but once it is installed on the test machine, it is then BLUE.
I believe this is the issue but I don't know how to solve it. Please see photos.
Thanks!
Ryan
(5,175 Views)
Accepted by topic author SimpleJack
Make sure in StationOptions that you are pointing to the correct 'Default' Process Model.  My guess you are pointing to an incorrect or non-existant process model.
StationOptions -> Model ( make sure the path in the Station Model is correct ).
PH
(5,162 Views)
with your 'before deployment' is this on your development system?
with your deployment, did you include the process model sequence files, or have you deployed these with your TS engine as part of a separate deployment.
Regards
Ray Farmer
(5,119 Views)
Teds,
Thank you so much for the information. It turns out that the deployment did not like haveing my process model outside of the default model directory. It was pointing to correct location for the model though.
I don't know why that is, but no big deal.  I put it back in there, recomplied, and it work!
Ryan
(5,116 Views)
