NI TestStand
Test UUTs button + others disabled in Operator Interface after deployment
I am using the Simple OI example in my code.
However after deployment to my deployment PC I can select my sequence but all of the TestUUT or run sequence buttons are grayed out?
I feel as this is something simple that, perhaps I have missed.
(3,912 Views)
Hi Taylor,
From what you have described it sounds like you may not have the right permissions set up for that user. Another thing you could try is deploying the full featured version and determine if the problem is specific to the simple OI or just a deployment problem. I have attached two links that give more information about deploying in general and deploying the OI. If these things do not work or you have more questions please let me know and please supply the version of Teststand, development computer OS, and target computer OS.
Patrick H | National Instruments | Software Engineer
(3,889 Views)
Check to make sure the process model you are specifing as the default in the Station Options window configuration is correct:
http://forums.ni.com/t5/NI-TestStand/Test-UUT-and-SIngle-Pass-missing-during-deployment/m-p/1266994#...
PH
(3,873 Views)
