NI TestStand
Test for System File and Delete System File
I have about 300 different tests that I run using TestStand, each with a somewhat unique report output filename:
  Example:  0-RMC 80 Timer_Interface_MaxValue_Report.html
The filename includes the
    Number of Errors
    Product Name
    Build Revision
      and a unique test name.
I would like to add a step to an existing initialization routine to test for an existing report file name and if it exists, bypass the test sequence.
The question is, how do I run a system command within TestStand to test for a file, for example:
  If (SystemCommand(dir Locals.ReportPath\0-RMC 80 Timer_Interface_MaxValue*.html) then
    Don't run this test...
Similarly, I also need to know how to delete a file from within TestStand.
    SystemCommand(Del 9999*.*)
Mike
(3,146 Views)
You can use the FindFile method in the TS API:
FindFile Method
Syntax
Engine.FindFile ( fileToFind, absolutePath, userCancelled, promptOption = FindFile_PromptHonorUserPreference, srchListOption = FindFile_AddDirToSrchList_Ask, isCommand = False, [currentSequenceFile])
The function itself returns a boolean which indicates if the file exists or not.
Then just use a Call Executable step to run command line string to delete the file.
Hope this helps!
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,139 Views)
