NI TestStand
Test socket does not show as disable
I run batch model and skip socket 1 during the run. Teststand 2014 does skip the socket but when the batch is completed. The display does not the test socket as disable but has a green check mark as the picture show Teststand 2010 working does show the socket was disable while teststand 2014 does not.
(3,892 Views)
Hi Tphan,
To clarify, when running a Batch Model in TestStand 2014 the socket is not skipped during execution, but it is on TestStand 2010. Is this correct? How are you disabling the test socket 1?
Briana P.
Licensing
Sr SW Engineering Manager | NI R&D
ni.com/support
(3,844 Views)
