NI TestStand
Test stand - selecting hardware resources
Hi.
When trying to open the Simple OI example attached in the previous post, I'm getting an error (besides many missed dependencies): "... TestStand Application Manager control requires TestStand version 4.5.0 or higher ...  ". Can you please provide .vi and .seq files compatible with LV2009 and TS 4.2.1.83?
Thanks very much for your help and patience,
Paul
Message 11 of 14
(1,070 Views)
Hello Paul,
Here is the sequence file in version 4.2.1. The LabVIEW project that I posted should already be in version LabVIEW 2009. Have a great day!
Best Regards,
Adam G
Message 12 of 14
(1,054 Views)
Thank you for your help. Indeed, the PostUIMessage is the best way to communicate between the UI and the .seq. I also found a way by using property nodes and methods in the VI, but it sure was a lot more complicated.
Message 13 of 14
(1,021 Views)
Also for other users that might run into the same problem, a VERY good reference forum thread related to the same problem of passing data to/from the UI: http://forums.ni.com/t5/NI-TestStand/Pass-parameters-to-teststand-using-LV/td-p/569411
Paul HARFAS
Message 14 of 14
(996 Views)
