NI TestStand
TestStand 2.0 Error: Unable to launch Active X Automation Adapter
I have 3 PC's using the same LabView Operator interface given from TestStand, but one of the PCs is giving me an Error "Unable to launch Active X Automation Adapter"
Please Help...
I have already uninstalled the TestStand Engine, and Labview Engines and then re-installed them, that didn't fit the problem.
(3,257 Views)
You may have to manual register the runtime ActiveX server, eg TestStandLVRTS /RegServer.
See the User Manual Chapter 17 Distributing TestStand.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(3,257 Views)
You may also want to check the knowledgebase entitled "How to Fix -18001 Errors when Using TestStand and LabVIEW":
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/55574cb4e0f326df862567fd0077e303?OpenDocument
This document describes the error you are getting along with a possible solution which has to do with the DCOM settings.
Also, there is another developer exchange posting that talks about this ("How do I successfully distribute the LV ActiveX Run-Time Server?"):
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=506500000008000000D4260000&ECategory=TestStand
Carlos Leon
(3,257 Views)
