NI TestStand
TestStand 2014 DeploymentUtility Warning: Required Runtime not included
Upon completion of the Build, I get a Warning.  The Warning states, "The installer does not include the following LabVIEW Run-Time Engines required to execute VIs:  LabVIEW 14.0.1 (2014 SP1) (32-bit)"
As you can see, it appears the correct RunTime is checked (SEE LabVIEW 2014 Runtime Checked.PNG).
Is this a bug?  Any ideas as to why we get the Warning.
             Note:  This Warning is causing problems in our automaic builder (Quick Build).
(4,380 Views)
Have you tried uninstalling the LabVIEW 2014 SP1 Runtime Engine and Reinstalling it?  Here are download links for the 32 and 64 bit versions.  Make sure the one you download exactly matches the version of LabVIEW you are developing on.
LabVIEW Run-Time Engine 2014 SP1 - (32-bit) - Windows
http://www.ni.com/download/labview-run-time-engine-2014-sp1/5198/en/
LabVIEW Run-Time Engine 2014 SP1 - (64-bit) - Windows
http://www.ni.com/download/labview-run-time-engine-2014-sp1/5197/en/
(4,326 Views)
