NI TestStand
TestStand 2014: Get UUT serial number
In main sequence I inserted an action which calls to a routine in DLL.
The prototype is:
int OpenBinFile (char *Number)
This parameter should be the UUT's serial number entered in this window:
Can you please advise ?
Thank you,
Zvika
(1,176 Views)
Hello, I tried this:
It works but the expression is red. Is it not a valid expression ?
Thank you,
Zvika
(1,170 Views)
