NI TestStand
TestStand 2019 PushOK SCC
Anybody had any luck getting this to work on TS 64Bit in Windows 10?  I just installed the PushOK SCC (64 Bit 1.8.9.0) and it doesn't even show up as a source control options in the TS config.
(2,639 Views)
hey back2rock,
64-bit TestStand supports 32-bit SCC providers only, could you give the 32-bit one a try?
For more information: Selecting a Source Code Control Provider
(2,566 Views)
I am using SVN Tortoise 64 bit (64 bit PC) with TS 2020 - 64bit. When checking in TestStand the SCC menu it is empty and no SCC can be selected.
  • Is it possible to still use the SVN Tortoise 64bit or it is simply not working?
  • If not, which SVN is recommended?
Thanks!
(1,310 Views)
