NI TestStand
TestStand 2022 32bit deploy utility not seeing the testStand runtime
I am using TestStand 2022 32 bit on windows 10.
I am in the process of creating the deploy installer for my seq, but for some reason the deploy utility is not seeing 4 packages that are installed.   for the purposes of this post I'll only focus on the test stand runtime.
I have tried repairing and uninstalling teststand to no avail.
Below shows both the package manager and the deploy utility.
Anyone have any ideas how to fix this?
(985 Views)
Accepted by topic author pboucher@werfen.com
The TestStand 2022 runtime is already selected in your image, see the "TestStand 2022 Q4 Runtime (32-bit)". I suspect that if you expand that item you will see "TestStand 2022 Process Models Runtime (32-bit)".
The two TestStand items missing that do not indicate a version are likely an earlier version of TestStand that you have or previously had on your system. I think you can ignore those.
For the other two, do you need "NI mDNS Responder" or "NI LabVIEW 2022 Deployment Framework"?
Scott Richardson
https://testeract.com
(956 Views)
Thank you,  I had looked at the further down TS runtime, but it did NOT specify which version.   When I installed it on a clean PC it said TS 2019 was installed and it needed 2022. so I thought that's what it was.   turns out the issue is more complex  (I am still working through issues). But for this question what seems to be happening is both 2019 and 2022 are installed with the 2019 version activated.   once I run TS version selector and choose 2022 the target PC mostly launches.   Also odd is that the install says it will be installing TS 2021 so there is still a lot to fix.
(946 Views)
