NI TestStand
TestStand 2022 Q4 & LabVIEW 2023 Q3
Hi to all
I got a Mail from NI that a new Version of the Test Workflow Pro is available with the fallowing Software:
If you take a look at the TestStand Compatibility page there is LabVIEW 2023 Q3 not listed!
Does any body know if TestStand 2022 Q4 is compatible with LabVIEW 2023 Q3?
Best regards
(1,896 Views)
Accepted by topic author python007
From my testing I haven't had any problems using that combination of TestStand/LabVIEW.
On that TestStand compatability page it also says: "Additionally, each version of TestStand also typically supports versions of LabVIEW and LabWindows/CVI that are released while the version of TestStand is still in Current Release Support or Mainstream Support."
Which would seem to cover the situation here. So my guess is they just haven't updated the page to reflect that.
(1,857 Views)
It is compatible, i am using that combination of TestStand and LabVIEW at my workplace.
Sergio Velderrain
Software Community Lead
CLA I CTA I LabVIEW Champion Emeritus
"Linkedin profile"
(1,821 Views)
Hello ShockHouse and sergiovelderrain
Thanks for your reply. So I will update to LabVIEW 2023 Q3.
@National Instruments it would be nice if you could update your compatibility pages.
Best regards
(1,811 Views)
