NI TestStand
TestStand 22 fails to open fireberd VI
I'm dragging old TestStand scripts forward into TestStand 22.  Having trouble forcing TS to open FB6000 LLBs (for a TTC FIREBERD 6000).  The legacy script calls the FB6000-Initialize.vi, which lives inside an LLB.  When I try to get TestStand to open the new path to the LLB, TS quits without errors.
I switched my LabView adapter to use the development engine rather than the real-time engine.  I also used the labview driver download to grab the latest FB6000 drivers.  I'm able to open the LLB file in labview and open the VI in question, it's just teststand barfing.  Any help appreciated.
(2,062 Views)
Which LV Version is the llb in? Do you have the appropriate LabVIEW TunTime Engine installed and configured?
(2,030 Views)
I grabbed the latest version from the driver download page, marked for LV2021.  I'm running the LV2022 development engine under TestStand 2022.
(2,021 Views)
Please consider installing the 2021 RunTime Engine, configure LabVIEW Adapter settings in TestStand accordingly and try again
(2,004 Views)
