NI TestStand
TestStand 3.1/3.5 under WIndows 7
Anyone has solved or patched the annoying problem of the sequenze menu ring of TS 31 and TS 35 under Window 7 ? I'm referring to the problem in scrolling, when you expand the menu only one row is deiplayed and you have to scroll on one row !!! I'd like to explain to National Instrument that many customer has PC with windows 7 but they have to use old version of TS (like 3.1 or 3.5) and this is a very big problem in developing apps.
Thank you to all.
Massimo Ponte
Message 1 of 8
(4,835 Views)
TestStand 3.1 and 3.5 are not supported on Windows 7.  If you would like to use those versions, we recommend using a supported version of Windows, such as XP.  If you can only develop on Windows 7, then TestStand 4.2.1 is the first version to support it.
Message 2 of 8
(4,832 Views)
Hello Massimo,
AlleP fully provided for clarify your question. Moreover, let me point you to a useful Knowledgebase explaining the National Instruments product compatibility for Windows 7. I hope it could help:
National Instruments Product Compatibility for Microsoft Windows 7
Please, feel free to write back if you need additional support.
Best regards
Matteo
Message 3 of 8
(4,749 Views)
I know that, but I'm a supplier of a big Automotive company that has many test benches with TS 3.1 or TS 3.5 and they don't want to spend money to upgrade TS on that systems but I have to continue to develop application on my PC with windows 7; a company like NI should think to this type of problems. Try to propose to a big company to upgrade 60-100 systems because of a little problem with old TS version.......
Thank you very much.
Message 4 of 8
(4,747 Views)
Hey Massimo,
I agree with you that it could be difficult to plan a system upgrades on several hundreds of machines. The upgrade/maintenance for a software framework is a very critical task for a company. However it doesn't explain how your company upgraded your Operative Systems without worrying about the Development System's compatibility. Anyway, you can easily workaround your issue by installing a Virtual Machine containing an XP OS and TestStand 3.1/3.5. Refer to following useful links:
WMware - Support and Licence
Have a nice day!
Bye
Matteo
Message 5 of 8
(4,741 Views)
seica1,
As Logan suggests, a virtual machine is probably the easiest solution for you. I recall Microsoft was even supporting that as a way to run older programs on Windows 7 so Windows 7 might even have some built in support for this. Also there are many virtual machine products out there, another one to consider is Virtualbox.
Hope this helps,
-Doug
Message 6 of 8
(4,727 Views)
I found a link to Microsoft's "XP Mode" for Windows 7. I think it's basically using their virtual machine software to run XP in a virtual machine.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Hope this helps,
-Doug
Message 7 of 8
(4,722 Views)
Just few days ago i manage to install my tester to windows 7. What i have try to solve the compatibility issue, i was installing visual studio 6 first in the pc, and after that start to install test stand 3.0. So far the tester can works properly.who knows it can solve the issue at your site.
Note. My tester is using simple application. Only controlling dcpower supply agilent and also multimeter, with plc communication(modbus).
Message 8 of 8
(4,028 Views)
