NI TestStand
TestStand 4.0.1f1 Evaluation and 4.0.1f1 Patch Available for Download
NI TestStand 4.0.1f1 has been released and is available for download.
This release fixes the incorrect behavior of the Insertion Palette control and Variables View control when used in User Interfaces after .NET Framework 2.0 Service Pack 1 or later has been installed.
If you have previously installed TestStand 4.0.1, you may simply install the patch linked from this KnowledgeBase to fix the behavior.  Distributions built from patched development machines will include the fix in their deployments.
If you have not installed TestStand 4.0.1 on your computer, you may install the evaluation of 4.0.1f1 and activate it with your TestStand development serial number.  The evaluation includes the fixed components from the patch above.  Upgrading from 4.0 to 4.0.1f1 is free and includes many bug fixes and improvements.
TestStand 4.0.1f1 Evaluation Software
If you require this patch for TestStand 4.0, please contact National Instruments Support to request it.
Message Edited by Josh W. on 02-05-2008 09:48 AM
Josh W.
Certified TestStand Architect
Formerly blue
Message 1 of 1
(3,794 Views)
