NI TestStand
TestStand API: Double Click to Call Sequence in User Interface
I would like to reproduce the same effect that in TestStand allows with a double click to open a sequence from a Call Sequence.
In the TS Full-featured User Interface (LV version) this functionality is not present, if you click 2 times on a step, the properties window is opened and the same happens for the call sequences, but in TestStand double clicking on a Call Sequence opens the corresponding sequence to which it refers (present in the sequence file).
(3,579 Views)
to get the effect you want you should change the TestStand user interface on LabVIEW, but it's extremely complex to do and honestly I'm not sure it's worth it.
Alessia
(3,538 Views)
Accepted by topic author Fizs
I did it, using DblClick Callback of SequenceView object.
(3,304 Views)
Fizs, I know it's been some time ago, but I'd like to do the same thing.  It appears that you did solve the problem, however, with your code snippet I cannot tell what properties or methods you are using.  Do you have another clip or an example VI that shows the expanded version of the properties and methods?
(1,357 Views)
Of course. I add the false condition too
(1,333 Views)
Hi Fizs
I'm interested how exactly you implemented this in the TestStand Full-Featured Operator Interface.
Can you tell me where in the Operater Interface you implemented this?
Best regards
(1,170 Views)
