NI TestStand
TestStand C# adapter - Constructor not showing input variables
This is where the release method is.
This is the piece of code for loadinf assembly. and myModule.ClassName = $"{Name_space}.{clasReferences.Name}"; loads the root class
Message 11 of 13
(96 Views)
OK, I understand a bit more now: the TestStand Code in one of the previous posts has been created using your .net code.
I recommend a cross check: what happens if you try to create this step manually with the exact same parameters? Will Release(int a) be available as expected?
If yes, there might be a something missing when creating the step. Maybe you want to try
Step.LoadModule(0) on the step in question.
Honestly, this is an educated guess, since my expertise is limited here...
Message 12 of 13
(82 Views)
Yes you got my point right, but step.loadmodule isnt working. Thank you.
Well i have one more doubt here. As am new to teststand am unsure about sequence context usage. I know that it is to create things dynamically, but should i be using it in my code?. i dont know if i should.
Message 13 of 13
(64 Views)
