NI TestStand
TestStand Crashes
Please help me with TestStand.  I am load a vi into my sequence file and shortly after TestStand pulls the vi in; it crashes.  Is there something wrong with my vi?
(3,728 Views)
It's hard to give you any direction if you supply so few details.
You should include, at the very least:
 * Operating System
 * TestStand Version
 * LabVIEW Version
 * The VI and sequence in question
(3,726 Views)
Operating System is Windows XP
TestSand 4.2.1
LabView 2010
The vi turns on a high voltage power supply and sets a voltage.  It works fine in LabView 2010 but when I pull the vi into my sequence in TestStand it shuts down.
(3,723 Views)
Do you have the TS patch referred in this KB installed? - link
Anand Jain
(3,713 Views)
I removed some logic from the vi and TestStand finally accepted the vi.  I am running now.
(3,709 Views)
Look at the patch info Anand posted. You likely need that too if you haven't already installed it.
-Doug
(3,669 Views)
