NI TestStand
TestStand Custom Step Type properties not modified
Hi all,
I have an issue with TestStand 2016 f2 : when I modify the properties of a custom step type, the modifications are not taken into account when closing the properties window (the properties were not grayed - I could make the modifications but they are ignored after closing the window ; the ini file is not read only).
Do you have any idea what could cause this behavior ? I know it worked once, right after installing TestStand but now it won't, even if I execute the sequence editor as an administrator.
It works perfectly on my colleague's machine with the same version of TestStand...
Thank you for your help
Christophe
Message 1 of 1
(2,262 Views)
