I have something unusual happening on two different testers using PXI controllers. In TestStand 3.5, I use the Configure -> Datalog... to set the Numeric Precision to "Use Step Format". I check the box and hit the OK button. If I immediately go in to check the setting, the check box is unchecked. The datalog results do not output using the step format. It seems as if TS is in a state where it cannot store configurations.
Anybody have any suggestions on what to try here??
Ron
