NI TestStand
TestStand Deployment Query
I have TestStand 3.0 development licence and once my development is finished i need to deploy my software to client machine. Do i need to purchase TestStand Base Deployment Utility,TestStand Debug Deployment Utility or can i can deploy by suing the option present in Tools->Deploy TestStand System.
If i need to buy Base or Debug Deployment utility then what is the purpose of this option Tools->Deploy TestStand System ??
Thanks in advance,
-Anil
Anil-B'lore
(3,419 Views)
Hi Anil,
The Deploy TestStand System is very good at organizing every code module and component that you need for a deployed system. It will find all of your VIs (if you use LabVIEW), and all of your other code modules. It will create a single installer that will include the TestStand Engine. However, you will still need to a license to run TestStand on the deployment machine. So you will use both the Tools >> Deploy TestStand System along with purchasing a deployment license for using TestStand on another machine.
Allen P.
NI
(3,381 Views)
Hi Allen,
Thanks for your reply. Now it is clear for me regarding Deployment of TestStand Applications.
Once again thanks for your reply,
-Anil
Anil-B'lore
(3,369 Views)
