NI TestStand
TestStand Deployment Utility Bug Fixes
I'm currently using TestStand 4.2.1 and recently received email about 2010 release.  I read 4.2.1 bug list here http://zone.ni.com/devzone/cda/tut/p/id/8681#172793_by_Category but was wondering if any of them got fixed in 2010.
Is there a list of Deployment Utility bug fixes included in TS 2010?
Would you recommend upgrading from TS 4.2.1 to 2010 if I have run into issues with Deployment Utility?  Most of my issues have been posted on forum but many without clear solution.
(3,846 Views)
Accepted by topic author bwv1043
Hi hellochicago,
I've attached an HTML version of the TestStand 2010 Readme file. This includes the list of bug fixes for this version.
As another note, the Deployment Utility has been highly improved in TestStand 2010, so I would recommend upgrading regardless.
I hope this helps!
Tanya Visser
LabVIEW Group Manager
(3,821 Views)
Thank you very much for the list.
(3,816 Views)
I upgraded to TS 2010 and all problems related to DU have been resolved.  I was able to successfully deploy TS with default UI, process model with minor modification, LV 2010 test code and a DLL which I developed in CVI 2009 SP1.
(3,767 Views)
