NI TestStand
TestStand Deployment build error -12 and 23
Hello...
I tried to create an installer of my Teststand project.
  • The sequence is developed using TestStand with Labview adapter.
  • There are other 2 configuration files (xls & csv) involves in the program.
  • At the end of the test, a report will be generated.
LabView 2012
TestStand 2012
Here is the logs from the deployment.
Starting Analysis
Processing Workspace...
Workspace Processed
Finished Analysis
Building...
3:42 PM
Copying distribution 'NI Developer Suite 2012 DS2 DVD 1' from: D:\ to: C:\Users\tokimaz\AppData\Local\Temp\NIMDFTempProductCopy3948\
*** Error: Windows SDK function returned an error. (Error code -12)
Could not copy file (source = "D:\Distributions\LV_DSC\Products\NI-LVCINT\LVCInterface\LVCInterface.msi"; destination = "C:\Users\tokimaz\AppData\Local\Temp\NIMDFTempProductCopy3948\{DEC25D81-2317-47F6-8B26-D54A939DA1EE}\LVCInterface\LVCInterface.msi").
Data error (cyclic redundancy check).
Error Details:
Error in MDF API function: _MDFProdPreview_GetUnavailableProducts
MetaToolbox: MetaToolbox::CopyFileIgnoreAttribs failed.
Windows function MetaCopyFileEx returned an error. Error code: 23
*** End Error Report
Loading product deployment information
The build is finished
3:44 PM
Aborted
(3,901 Views)
Hi Toyan,
silly question but do you actually have the NI Dev Suite DVD inserted in the 😧 drive when you tried this?
The first error just states that it can't copy the file. That could either be that the DVD is not available or that there is a permissions error in the AppData folder (which is where it is trying to copy it to).
The second error looks like a dependent error based on the fact that it couldn't copy the file.
Best Regards
Mathis
(3,818 Views)
