NI TestStand
TestStand Deployment fails due to lvanlys.dll
I've created a Test Sequence that utilize test VIs compiled into a packed library file. The sequence works and we're getting ready for deployment the problem is that when I try to build the Deployment, the build fails because it's looking for lvanlys.dll (see the attached screenshot)
What's baffling is that lvanlys.dll is at the specified destination. Even when I include lvanlys.dll in the packed library build, the TestStand Deployment utility doesn't seem to recognize it and give the same error. Has anyone encountered this issue before?
(1,233 Views)
Hello
Try to reinstall the labview run-time engine. Make sure matches with your labview development version.
(1,145 Views)
