NI TestStand
TestStand Error
Hi.
I need help.
Running TestStand in my PC environment results in an error.
OS had no problem in win7 but it is happening in Win10.
The contents of the error are as follows.
Run-Time Error
Details :
An error occurred while performing the switch operation 'Connect' for the following device 'TMP5410'.
Could not perform the switching operation:
Details:This session is not a valid NI Switch Executive virtual device session.(Error = -29003)
Error code :
-17500; Operation Failed.
Step 'Switch ON' of sequence '1.Shutdown Current' in 'TMP5410_ver.0.1_200522.seq'
TestStand ver. : 2016 Service Pack 1
Lab-view ver. : 16.0f5
I want you to find the answer to my question.
(1,912 Views)
It looks like you haven't set up your switch executive properly on the new machine.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,869 Views)
