NI TestStand
TestStand Execution ID for Database
I am working on sending test results to our database with TestStand database option. In our database table, we have a column which is called "__Sys_Instance_ID". In database viewer, it looks like:
In our software which is used to send data to database, I saw that it is equal to Execution ID:
In TestStand, I saw the object reference Execution as:unnamed (1).png
When I use variable Runstate.Execution.ID, I cannot get the number 7DC7E990-18DC-111D1-.....
How can I get this number and what is its type? How can I create it in Database Options, Schemas tab?
Saygılarımla,
(2,711 Views)
HI Saygılarımla,
The Execution IID is the GUID of the Execution COM class. It will be consistent for every execution. Is there a reason that you wanted this information in your database?
(2,652 Views)
