Hi
I wanted to get this question it's own thread. So, here's the problem. In TestStand I have 10 steps. The first step should open a front panel for the user. This front panel has listing of different voltage measurements. These results should came from the steps following the opening of the user interface. How is this done? I can't get the test sequence to advance, because the first step, used as the user interface, is not finished. If I close it, I cannot update the actual measurement (steps) results to it?
Aleksi Sandqvist
