NI TestStand
TestStand Freezes in LabVIEW development, but not when compiled
I have a LabVIEW application that calls TestStand via the APIs.  Running TestStand 2021 SP1.  Both 32 and 64 bit versions are installed.  Running LabVIEW 2023Q3, 64 bit.
My code runs just fine when I compile it.  However, when I run it in the development environment, it freezes.  All of LabVIEW freezes.  Can't access the project any more, the close buttons quit, and the three other top-level's freeze.  All I can do is hit contorl+alt+delete.
In the executable, the sequence file loads and executes just fine.  In the development environment, it preloads the modules, but the sequence never shows in the ActiveX container.  It just stays blank.
Below is my top-level.
I have some logging routines, all the code in this state executes, and it goes on to the next state, and after a period of time later, it freezes (in the development environment).    So, I put a never ending while loop in this case to stop it from progressing to the next state, and it still freezes.. so I don't think it's subsequent code.
I added the case structure to see where it fails.  Both the development and the compiled code work fine, if I set the case structure to off.  When I run the case structure code, it's fine in the compiled, but freezes in the dev environment.
Forgive the verbose logging and error handling.  The code (in both environments) executes w/o error.  All the log entries get written.
However, when I put a diagram disable over the run method, it no longer freezes in the dev environment (of course the sequence don't run).  So, in my mind, that leads to me doing something funky with how the run method gets called.
Can you see anything that would cause this code to run fine when compiled, but freeze a few seconds later, when ran from the LabVIEW dev environment.
Also, all the sequence does is loop wait statements (does nothing).
-josh
(669 Views)
Wild guess: if you have TS engine acquired in one of your subVIs, try to set this VI execution system to different than "same as caller". For example try "other 1".
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(639 Views)
