NI TestStand
TestStand Hex Limits
I am wondering if there is a way to extend the hex limits, currently I am using v4.0 and it does not allow numbers over 8 bytes (0xFFFFFFFF = 4294967295).
Ex:
0x0000000000    --    Accepted
0x0000000008    --    Accepted
0x0000000080    --    Accepted
0x0000000800    --    Accepted
0x0000008000    --    Accepted
0x0000080000    --    Accepted
0x0000800000    --    Accepted
0x0008000000    --    Accepted
0x0080000000    --    Accepted
0x0800000000    --    Not Accepted (gives 0x00FFFFFFFF)
0x8000000000    --    Not Accepted (gives 0x00FFFFFFFF)
I am trying to send CAN messages that have larger HEX values.
(3,017 Views)
You need to use an array or a string if you need more space (bytes).
The number size is derived from a PC hardware limitation not software (64bit).
(3,012 Views)
