NI TestStand
TestStand LabVIEW User Interface Context Menu
I am using TestStand 2016 and LabVIEW 2017. If I run the full-featured LabVIEW user interface (shipped example), I get the following context menu when I right-click on some test step.
I wanted to get the same context menu on the basic user interface (another shipped example). I copied and slightly modified the SequenceView CreateContextMenu Event Callback from the full-featured example. Now I get the following context menu for the same test step on the basic user interface. It lacks many options.
Where does this difference come from? Any input will be appreciated.
(3,784 Views)
Accepted by topic author Chickentree
This is what I'd expect to see when running in Operator mode vs Editor Mode. Make sure you are running as Editor.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(3,772 Views)
Yep, that was it. Thank you!
(3,769 Views)
