NI TestStand
TestStand LabVIEW adapter bug? The timestamp format (Error -17300)
I just wanted to inform you about probable bug in LabVIEW adapter which is related to timestamps.
If we have a VI with timestamp input and we call it from TestStand we might see the error (see below) if our input is an empty string.
Details:
Parameter 'time in':
The Timestamp value specified does not have the expected format: mm/dd/yyyy hh:mm:ss.sss AM/PM
Error Code:
-17300; Value invalid or out of range.
Step 'Action' of sequence 'MainSequence' in 'TimeTest.seq'
But it appears ONLY if I use LabVIEW runtime engine.
See the attachment (set RTE in the adapter settings).
May I ask someone from NI to confirm the bug and report a CAR?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
Message 1 of 1
(1,936 Views)
