NI TestStand
TestStand License Restore
In a Test PC the motherboard had to be replaced. Now TestStand 3.0 has problem with the license. How do I restore the license to the repaired PC?
(4,422 Views)
Accepted by topic author Lou1
You can probably just reactivate it. Run the National Instruments License manager and right-click on the teststand license and see if it gives you the option of activating it.
-Doug
(4,421 Views)
Doug,
I also have a TestStand License issue. I am completely replacing a controller on a piece of equipment. This equipment is critical to production. The vendor who sent the new controller has already installed TestStand and said I need to transfer the license from the Damaged unit. Is there a way to do this before I pull the old unit out ? I need to plug the new unit in and have it running fast.
(4,312 Views)
If you can still access the old controller, you could just deactivate the license. You can then use the same serial number and activate on the new controller
Humphrey H.
(4,295 Views)
That is good, Is there a license manager or utility in TestStand.? This is the only unit we have with TestStand. It is always running and we have no opportunity to experiment with it. So TestStand is a totally foreign environment, I have no idea about the interface. I am good with CVI, LabView, and such, but TestStand -no-.
(4,289 Views)
There should be a National Instruments>>NI License Manager item in your Windows Start menu.
(4,286 Views)
