NI TestStand
TestStand Message Popup
Can we store the "Initial Response string" into local variable for my further reference?? MessagePopup->Edit Message settings->Options->Enable Response Text Box.
-Anil
Anil-B'lore
(9,416 Views)
You can access the response string entered by the user from the Run State object of the sequence.
For example :- Locals.Response= RunState.Sequence.Main["Message Popup"].Result.Response
In above statement i am assigning it to Response(My Local Variable) from the run state object of step called "Message Popup"
Please check the attachment.
Anuradha
(9,412 Views)
You could also place the following assignment in the Post Expression for the Message Popup step.
Locals.Response= Step.Result.Response
Doing this would not require a second step.
Scott Richardson
https://testeract.com
(9,401 Views)
Or if you want to start of with some text in the response string when the dialog first appears.
Put in the Pre Expression of the MessagePopup step
Step.DefaultResponse = Locals.Response
Regards
Ray Farmer
Regards
Ray Farmer
(9,394 Views)
Hi Anuradha,
Thanks for your reply.
-Anil
Anil-B'lore
(9,359 Views)
