NI TestStand
TestStand One step failed but UUT Passed
TStand 2.01, OS 2000, report format Txt.
My test run OK, the step failed (STEP:LBH_LeakP, Measurement[0]). However, at the top, the UUT status = passed. Please help it should be failed
(3,304 Views)
Trout00 -
Check to see if the option "Step Failure Causes Sequence Failure" is set for this step on the Run Options tab of the Step Properties dialog box. If it is set and the failure is not propagating, please attach an example sequence that causes the behavior that you are referencing.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(3,304 Views)
Thank you, I go check the box
(3,304 Views)
