NI TestStand
TestStand Operator Interface Hangs When Preloading Modules
HI,
I have the below mentioned issue.
However, I am unable to find which file has "ESys.StdNParallel=0".
I have added into LABView.ini located in following location:
C:\Program Files\National Instruments\LabVIEW 2019
LabVIEW.ini
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DthtCAC&l=en-US
Is there any location where it needs to be updated or checked ?
I have added the following.
Please help as it continues to loop forever!!
(527 Views)
Is your OI running as ane executable?
If so, have you performed a fresh build with the settings in the LabVIEW.ini?
(511 Views)
