It seems like there's no up to date information on using PostgreSQL with TestStand.
I've seen and tried the stuff here:
- https://forums.ni.com/t5/NI-TestStand/Trouble-integrating-PostgreSQL-database-into-TestStand/m-p/316...
- https://forums.ni.com/t5/NI-TestStand/Database-loogging-with-TS-postgresql/td-p/1599862
- https://www.connectionstrings.com/postgresql-odbc-driver-psqlodbc/
- https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019fkgCAA&l=en-US
Using the versions that specify a connection string, I get:
"Object Reference not set to an instance of an object"
Following the knowledgebase article I get:
Then "some settings were not acceped by the db provider"
And view data generates errors. I've tried "Database management System" types.
