NI TestStand
TestStand Report Generator Needs to be More User Friendly
Can you resend the sequence in TestStand 2012. It appears to be a newer version which I can't open.
Message 11 of 24
(2,467 Views)
Here it is in TS2012 and LV12.
Message 12 of 24
(2,464 Views)
I was able to open the TestStand 2012. The LV file still shows it's a later version and does not open. I have LabVIEW 2012 SP 1.
Message 13 of 24
(2,461 Views)
I removed the LabVIEW step and ran the TestStand sequence.
I get a Run Time error:  An exception occurred inside of the call to .NET member 'GenerateReport':
System.Runtime.InteropServices.COMException (0xFFFFBC6B): Index out of range.
   at NationalInstruments.TestStand.Interop.API.ReportSections.get_Item(Object index)
   at NIOTFReportGenerator.CollectionStepResult.UpdateExisting(IStepResult updatedStepResultI, Boolean usingConserveMemory, ReportFileStream& tempFileStream)
   at NIOTFReportGenerator.OTFRptGenerator.GenerateReport(SequenceContext sequenceContext, String inputReportHeader, String inputReportFooter, ReportSection& mainSequenceReportSection, String& errorMessage, Double& errorCode, Boolean& errorOccurred)
Message 14 of 24
(2,460 Views)
I get a Run Time Error on the TestStand sequence.
Have you tried running it?
Message 15 of 24
(2,450 Views)
Yes, and it puts the report in the seqlocation\testname\ folder automatically.
The test sequence may still be linked to the labview 2016 version. See if you can point it to the one in the MoveReportFileLV12.vi folder. That VI is the same but saved for labview 2012.
Message 16 of 24
(2,447 Views)
Step 'Generate Report' of sequence 'ProcessOTFStepResults' in 'ReportGen_html.seq'
Message 17 of 24
(2,442 Views)
Turn off on the fly reporting.
Message 18 of 24
(2,438 Views)
Okay, there's a new error.
Item is locked, protected, or in use and cannot be deleted.
Error accessing item 'ResultList'.
Message 19 of 24
(2,434 Views)
Is that error occuring inside the VI?
Message 20 of 24
(2,432 Views)
