NI TestStand
TestStand Result
Is it possible to write TestStand result in an Excel sheet?
When we check the working of 8 BOOL  I/O structures(In Labview), is it possible to write the results onto an Excel Sheet?
(942 Views)
I would recommend to create a "Result Processing Plugin". There you can use the "on the fly result" callback to implement your desired functionality.
CLA / CTD
(888 Views)
