NI TestStand
TestStand - Run continously
Hi everyone,
I would like to ask how to implement this on Test Stand.
I have my sequence where it performs different operations.  I was wondering how to create data log a data every 5 ms. My data log should be like this
Time X
0       1.21
0.5    1.05
1       12.09
(1,297 Views)
Hello RSA12309
I found articles, where you can find some instructions and steps how to create and log data. Try to go through these articles and you will find some answers.
Database Logging - NI
Database Step Types - NI
Log Test Results to Databases with TestStand - NI
Using Databases and Reports with TestStand - YouTube
Regards)
(1,221 Views)
How it should work exactly? Is it a loop in the MainSequence in which you run some continues measurements? And you want to log those measurements every 5ms?
In general for data logs I would suggest Data Streams. However, it is not clear to me what do you want to achieve 🙁
Side note: I don't think we can talk about exact 5ms interval on Windows.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,198 Views)
