NI TestStand
TestStand Run-time Engine Deployment
For the latest TestStand version, is there a way to use the base deployment version without having to enter a license number?
Thanks!
(4,354 Views)
I don't think so... to run the base deployment engine you need to purchase a base deployment license.
(4,343 Views)
The above poster is correct in that you must purchase a base deployment license, however if you have a Volume License Agreement and are using Volume Licensing you may point the machine to the license server so you will not have to enter a number on the client, it will be handled on the server side.
Is this something you might be interested in?
Here is a KnowledgeBase article describing TestStand Licensing.
Here is a KnowledgeBase article describing which National Instruments products require deployment licenses.
With warm regards,
David D.
(4,332 Views)
