NI TestStand
TestStand Sequence Editor Float Pane not available?
Using TestStand 2019 the sequence editor option to float a pane is greyed out. I've checked Configure>>Sequence Editor options>>UI Configuration and the lock is off (unchecked) and nothing else is checked except Display documents in Tabs.
Any Ideas as to why? According to Help I should also be able to drag off window to float but that doesn't work either. Rearrange and Hide all works.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 1 of 14
(3,355 Views)
Which pane are you referring to?
Message 2 of 14
(3,041 Views)
Any of the panes in the sequence editor. If I select the down arrow "Floating" is greyed out while "Hide" and "Auto-Hide' are available.
Message 3 of 14
(3,017 Views)
I have the exact same issue, no idea why this is no longer configurable
Message 4 of 14
(3,005 Views)
Have you tried toggling View>>Lock/Unlock UI Configuration ?
Message 5 of 14
(2,997 Views)
I just tried that and It doesn't make any difference in the ability to float the pane. If I lock it I can't drag the pane though. The lock glyph does change accordingly.
Message 6 of 14
(2,992 Views)
Yes. It has no effect.
Message 7 of 14
(2,987 Views)
May you please confirm if "Insertion Palette" and "Step Settings" panes also have Floating option dimmed?
Message 8 of 14
(2,976 Views)
My insertion palette is currently floated, and has been for as long as I've been using TestStand. I can return it to the main window and float it again without difficulty. Step settings can also be floated, it is only the 'sequences', 'variables', and 'steps' panes that have it disabled.
Message 9 of 14
(2,971 Views)
I never really checked those "Step Settings" and "Insertion Palette" before for floating. I concur with Ian_A...those can be floated and respect the Lock and UI Configuration rules.
Message 10 of 14
(2,968 Views)
