NI TestStand
TestStand Sequence Editor message
I have tried the options below but I am still getting the same error.
Is there another thing I could try?
Feedback is very much appreciated.
Message 11 of 15
(1,196 Views)
Can you backup and delete all files under the directory equivalent to <TestStand_LocalAppData> and then try to launch the SeqEdit.
In my machine, it is C:\Users\<user_name>\AppData\Local\National Instruments\<TestStand 64-bit version>.
You might have to also backup and delete files below C:\Users\<user_name>\AppData\Local\National Instruments\<TestStand 32-bit version>.
Can you please post the original files so that we can diagnose the issue better.
Anand Jain
NI
Message 12 of 15
(1,189 Views)
Hi Anand Jain,
This fixed my problem:
1. Backup and delete all files under the directory equivalent to C:\Users\<user_name>\AppData\Local\National Instruments\<TestStand 32-bit version>
2. Launch the SeqEdit
Nothing is grayed out, popup is gone back to developing...
THANK YOU!!!
Can this be added to the list of things to try under Solution?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000wwyACAQ&l=en-US
Message 13 of 15
(1,185 Views)
Hi Aok2021,
Yes, we will update that KB. Can you post the files that were in the folder when you hit the issue?
Thank you
Anand Jain
NI
Message 14 of 15
(1,182 Views)
This solved the problem for me, thanks.
Message 15 of 15
(533 Views)
