NI TestStand
TestStand Simple OI unload sequences?
All,
I'm trying to verify if the TestStand Simple OI (LabVIEW) unloads a sequence when a new sequence is selected to run, I'm fairly new to TestStand interfacing with LabVIEW and I just want to verify, somehow, that there are not multiples sequences loaded at the same time; would anyone be able to help me out?
-Bill
John 3:16
(3,296 Views)
Bill,
If it shows up in the drop down then it is open.  So just opening a new one does not close the previous one.  You have to explicitly click the Close Sequence File button.  Or you can change the simple OI to handle this when a new one is opened.
However, opening a new sequence file does make the new one the "current" sequence file... i.e. it is selected.
I did verify that they are both opened by putting a property node on the application manager and getting the sequence files reference then using another property node to get the count.  It returned that both sequence files were indeed open.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,284 Views)
