NI TestStand
TestStand State Machine
I am looking for an example sequence that shows a state machine design pattern in TestStand 3.1.  Does anyone know if such an example exists?
Stephen
(3,512 Views)
Hello Stephen,
I have not run across a state machine example for TestStand, but you could easily implement a state machine with a Select statement nested inside of a While loop.  Each case of the select statement would represent a different state.  I hope this helps.
Best Regards,
Software Engineer
Jett R
(3,487 Views)
