NI TestStand
TestStand Subsequences
Could you please elaborate on the "No"?
Message 31 of 33
(1,208 Views)
2) Is it true that if I create embedded sequences as described in (1), I can then use these sequences ONLY within any of those same embedded sequences.  Are these, in effect, private sequences (to borrow from OO).
If you create an embedded sequences (using your words) you can access these from the ant sequence(s) within the embedded sequences and any external sequences
ignore this response!!!!!!!  slow network
Message Edited by Ray Farmer on 06-20-2006 01:07 PM
Regards
Ray Farmer
Message 32 of 33
(1,204 Views)
If you create an embedded sequences (using your words) you can access these from any sequence(s) within the embedded sequences and also any external sequences (eg contained in another sequence file). Therefore they are not private but public.
Hope this clarifies the No.
Regards
Ray Farmer
Message Edited by Ray Farmer on 06-20-2006 01:06 PM
Regards
Ray Farmer
Message 33 of 33
(1,204 Views)
